superduty injectors in an OBS?
Old Nov 21, 2011 | 07:50 PM
snow's Avatar
Default superduty injectors in an OBS?
Will 99 up injectors work in my 94 powerstroke? looking for some additional power and found set for cheap. Any opinions?
Old Nov 21, 2011 | 07:51 PM
RanchhandTCR's Avatar
I dont belive so. I know they made a few changes after 99
Old Nov 21, 2011 | 07:57 PM
snow's Avatar
i know the later injectors pushed more fuel which is what i'm looking for but i dont know if they are compatible with the older engines.
Old Nov 21, 2011 | 09:25 PM
95powersmoker's Avatar
They will work in a way... Will they be efficient or run perfect? No...
The Superduty injectors are split shots and your truck is programmed for single shots. There is a difference in timing. You will want some custom tuning to run the sd injectors correctly.
In my opinion, they aren't worth it, doesn't matter how cheap you get them.
Diesel performance isn't cheap. Either leave it and drive it, or buck up and pay to play...
Old Nov 21, 2011 | 09:26 PM
CSIPSD's Avatar
They will "fit" fine... the issue will be programing... OBS injectors are 90cc single shots... Superdutys 99.5 and up are 140cc SPLIT SHOTS.
Lots of people do it, not a major issue, just let your tuner know. You will run into HPO issues as the AD injectors use ALOT more oil then the AA injectors.
Old Nov 22, 2011 | 12:35 AM
joebob3093's Avatar
Moderator
I ran ADs in mine for a couple years with no issues till they got worn out. I ran them with stock aa programming.
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
