rebuild kits for 05 dodge?
Old Nov 20, 2011 | 04:14 PM
JJ75's Avatar
Default rebuild kits for 05 dodge?
Hey was wondering if anyone had some good advice on a rebuild kit for my 05 dodge cummins?
Is there any performance upgrade I should do while I have the engine torn down, asking for any helpful advice.
Thank You, JJ
Old Nov 20, 2011 | 08:51 PM
cummin_un_glued's Avatar
FormerVendor
if it were me and i had the cash to do it i would stud the head and put some good valve springs in it and on the bottom end i would change to 12v rods with A1 bolts, stud the mains, and i would put a 181/210 cam in with new lifters, and total seal rings...other then that just the basic genuine cummins gasket kits
Old Nov 20, 2011 | 08:57 PM
wildbill's Avatar
Also, make darn sure that the block is CLEAN!! Don't do a polish job on the crankshaft, have it reground. All new pistons, rings, bearings, cam and lifters as mentioned. Have the block bored out and re-sleeved to standard bore. Have the cylinder head checked out and repaired as necessary.
Go through everything possible.
Old Nov 20, 2011 | 10:21 PM
FormerVendor
other thing go thru the head too, we got one at the machine shop right now that to the eye looked fine but after it got there it needed 4 valves and 5 seats so have the head checked out for sure, and as bill said if the block is messed up have it fixed right
Old Nov 27, 2011 | 03:45 PM
JJ75's Avatar
Thank you guys so much for the advice any certain place you recomend for the parts
Old Nov 27, 2011 | 07:42 PM
FormerVendor
i can get ya everything if you would like
Old Dec 22, 2011 | 03:07 PM
JJ75's Avatar
Hey there was thinking about just going with a remanufactured engine, just swapping my parts off of my engine on to a rebuilt . What do you think of this idea? And do you know any body who carries these?
Thank you JJ
Old Dec 22, 2011 | 10:40 PM
FormerVendor
they are very expensive at most of the places that do actually have them. if i had a good core i could build you one but all of my cores are older engines.
Genos Garage
Genos Garage
Aug 3, 2015 09:29 AM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
