how much power will it take?
Old Nov 19, 2011 | 10:11 AM
cfarley0210's Avatar
Default how much power will it take?
As u can see by my signature my truck is built to handle quite a bit. The only thing i worry about are the internals on the bottom end. Like the rods crank and pistons not able to handle the power, is there someone out there with a super powerful motor that still has stock internals?
Old Nov 19, 2011 | 11:04 AM
BriteWhiteRam's Avatar
once you push past 500hp it seems the stock rods just cant handle the torque
Old Nov 21, 2011 | 07:15 PM
Not really what i was hopeing to hear. So if i were to get some twin turbos then ur sayin i will most likely need to build the bottom end?
Old Nov 22, 2011 | 12:24 PM
1AMatt's Avatar
Site Sponsor - 1aauto
I would say with twins you would need to change out the rods!
Old Nov 22, 2011 | 01:13 PM
2500HeavyDuty's Avatar
with what you have right now your fine.
Old Nov 22, 2011 | 01:50 PM
turbostang7's Avatar
yep you get twins your rods will get a little shorter
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
