2001 5.9L or 2004 5.9L ?
Old Nov 4, 2011 | 11:01 PM
JoeC7711's Avatar
Default 2001 5.9L or 2004 5.9L ?
I am currently looking at two trucks right now that i would like to get, one is a 2001 Dodge Ram 2500 5.9L 24 valve with 147K miles and the other is a 2004 Dodge ram 2500 5.9L 24 valve High output with 204K miles and a rebuilt transmission with around 12K miles on it. both trucks are automatics witch is what i want and both are free of rust. Im leaning more towards the 2004 just because its a newer truck but the 2001 is in excellent condition and low miles. both trucks are all stock as well. so witch one would you guys take?
Old Nov 4, 2011 | 11:20 PM
torqctd's Avatar
I'd go with the 04 with the rebuilt 48 RE tranny......I have 314,000 miles on my 04, and she runs strong.
Old Nov 5, 2011 | 09:12 PM
turbo2332's Avatar
the commom rail is WAY faster than the 24V in stock form. i personally would go for the 2001. prolly gonna be a bit cheaper and with the money you save you can upgrade some of its weak links. its hard to beat low miles. A trucks a truck doesnt matter if the engine runs like a top if the rest of it is ready for an overhaul...
Old Nov 7, 2011 | 05:43 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Lower miles is def a plus, but still 204K is not bad for the engine... I would personally go with the 04 as well!
Old Nov 7, 2011 | 05:51 PM
RanchhandTCR's Avatar
I like the 01's because of the way they drive they just feel better to me, I like common rails, but I dont mind the VP44 I take the lower miles. You can make an VP44 into a Common rail if you want to. How you do it is beyond me. Plus I think 01's are eassier to work on over a 04. My two cents.
Old Nov 8, 2011 | 11:42 AM
1AMatt's Avatar
Whats the price on the two rigs? That would be a deciding factor!
Old Nov 12, 2011 | 04:10 PM
bluedieselram's Avatar
id go with the 01 less miles and parts are cheaper and personally id rather have a 24valve then common rail
Old Nov 20, 2011 | 08:43 PM
tcarico's Avatar
after 100k - 150k the injectors in a common rail are prone to going bad. When they do they can melt pistons and more. Plus they are over $1000 for a set for the stock ones. You can get a set of 100 hp injectors for a 2001 for 600
Old Nov 20, 2011 | 08:50 PM
Smarty=Cummins's Avatar
I have an 01 and if you pull anything the transmission will go out just with a stock motor. At 165000 I had to replace my transmission and then I bought my upgrades. I would go with the 04 it will be a better deal.
Old Nov 20, 2011 | 09:26 PM
tcarico's Avatar
i run the crap out of mine with the quadzilla and pull a 12000 - 15000 lb trailer often and im still on the stock tranny. Fluid temp never gets over 150℉ towing.
