where to go next?
Old Oct 27, 2011 | 08:28 PM
articfox's Avatar
Default where to go next?
i have a 2001 ford f250 k&n cold air intake 5 inch strait pipe exhaust and edge juice with attitude im gona put a lift on it next but where should i go next any subjections? i allso have bigger tires
Old Oct 27, 2011 | 09:39 PM
95powersmoker's Avatar
Gauges would be good to have...
Old Oct 28, 2011 | 05:57 AM
TXtinct's Avatar
X2 on the gauges.
Old Oct 28, 2011 | 06:04 AM
Powersmokin32's Avatar
Gauges and a mild turbo upgrade
Old Oct 28, 2011 | 06:18 AM
TXtinct's Avatar
What type of turbo upgrade would you suggest?
Old Oct 28, 2011 | 06:36 AM
For what is done now and maybe adding a mild set of injectors in the future (im guessing as a lot of people do). I would go to a 38r as it is a mild upgrade to keep EGT's in the safe zone.
Old Oct 28, 2011 | 09:27 AM
Lets determine a power goal and a budget before we go assuming we need a turbo and injectors...
Old Oct 28, 2011 | 09:43 AM
I only recommend a turbo to help keep EGT's in a safe zone. Because with any hot tune you can have excessive exhaust temps and even compressor surge at times. Depending on driving style.
Old Oct 28, 2011 | 09:47 AM
Recommend what you want but the stock turbo can handle everything he has at this point and there is no point in buying a mild turbo for stock injectors and tunes and buying another turbo later for bigger injectors...
Again, need to determine a REALISTIC hp goal and budget... If you want 500hp like everybody else better have a thick wallet...
Old Nov 2, 2011 | 08:12 PM
articfox's Avatar
i have gauges from the edge works great im just looking for mild preformace right now more power ect normal step from stock
im in collage right now n working part time at a semi good paying job anything thats afordable i plan to go big later when i have a thick wallet. im just looking for a step up from stock no idea realy where to go i got it tuned all the basics
