She won't start!!!
Old Oct 22, 2011 | 06:15 AM
6.5 Man's Avatar
Default She won't start!!!
I have a 1996 6.5 diesel suburban, I got close to another 100k so bought the works to upgrade!
Pressure washed engine & couldn’t get it to start, waited a week then it started… ran fine for 20min then wouldn’t go over 2 or 3 RPM!
Waited another week & it ran like a champ… then went back to the same problem a week later!
I hadn’t done any work on it yet so I started discovered gas line had a slit in it so I went to summit & bought gel lines & replaced all of them (where hoses are).
Before putting intake on I started the truck to make sure IP lines where not leaking.
Put it back together now dam thing won’t start??? I’ve bleed the lines checked the flow to injectors still nothing!
I was old that the PMD was the source of my problem from the start so got a aftermarket PDM & moved it!
Still no start!!! SOS I need help this is my money maker & I aint making any… just spending right now Signed broke as Hell!
Old Oct 25, 2011 | 04:10 PM
Cumberland6.5td's Avatar
I just went through the same problem. Clean all your grounds on the motor, batt, firewall, fender and frame. if still nothing check power to your fuel shut off solenoid, make sure its working. Hope it helps.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
