Leak from Fuel Tank
Old Oct 18, 2011 | 11:33 PM
NMayse7's Avatar
Default Leak from Fuel Tank
I have a 97 12 valve Cummins with a slight fuel leak coming from the top of the tank and running down the sides and dripping off the bottom, not sure if I need some sort of gasket or if it's something wrong with my sending unit. Any info would help, thanks.
Old Oct 19, 2011 | 12:07 AM
gradyc's Avatar
We had the same trouble with our 92.It turned out that the sending unit lock ring had come loose. I think there a couple of vent hoses that fit into rubber grommets that could also break and let it leak or a broken return hose. Either way it is probably not hard to fix.
Old Oct 19, 2011 | 11:35 PM
NMayse7's Avatar
Not too expensive either?
Dbleo351
Nov 20, 2016 09:34 AM
vicktorious
Jul 1, 2015 12:10 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
