winter oil
Old Oct 18, 2011 | 07:48 PM
92idi's Avatar
Default winter oil
living in wisconsin it gets pretty cold here come winter....would it be recomended to run a light oil say motorcraft 10w30...or a 5w40 vs 15w40?
Old Oct 20, 2011 | 08:36 PM
92idi's Avatar
anyone?
Old Oct 21, 2011 | 11:43 AM
CARP's Avatar
I would say no. Stick with 15w40. Just give your engine time extra time to warm so that the oil thins out a bit.
Old Oct 26, 2011 | 01:21 PM
4x4manonbroke's Avatar
you can use 5w-40 all year.... the 5w means its thin while cold but retains the 40w thickness when its warm i run it get better fuel economy with the thinner oils and still good coverages ..... its what all the new trucks are running ... no fear my friend you'll be good with the 5w-40.... use synthetic too its great I'm getting 20mpg.......88 7.3 4spd no O/D 3.55's with 35's 4x4.... you will see the difference
Old Oct 26, 2011 | 05:17 PM
Heath's Avatar
Authorized Amsoil Dealer
I'd go 5W-40 if you wanted to go lighter.
Old Oct 27, 2011 | 07:29 PM
92idi's Avatar
would you recommend goin to synthetic with 24,0000 on the clock?
Old Oct 27, 2011 | 08:14 PM
Heath's Avatar
240,000? You can. I switched my. 94 at 269000. It was using a qt every 3000 but I did it anyway. I figured it would get worse but it didn't. Actually improved to every 4500 over time. That's not usually the cAse. If it is not using or leaking much then it should be fine. You might do a flush.
Old Oct 27, 2011 | 08:18 PM
92idi's Avatar
only leak i know of is my valve cover but that will be done before i change the oil..recomendations? rotella?
vin_diesel
Mar 1, 2016 01:43 PM
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
