alternator
Old Oct 16, 2011 | 08:39 PM
keller28's Avatar
Default alternator
my batteries keep running dead and gauges show very little power. i replaced the alternator and my batteries are still not receiving any charge. any ideas or hints to what might be the problem.
(note) my batteries are good, just low charge.
Old Oct 17, 2011 | 09:10 PM
CARP's Avatar
You may have bad wiring to the alternator. Make sure all wires are good and connected.
Old Oct 26, 2011 | 02:11 AM
Sandman8105's Avatar
I think mine turned out to be the battery cables.
Old Oct 29, 2011 | 10:27 PM
keller28's Avatar
i think i figured it out. i put new a voltage regulator on and its holding charge, but when i have truck on it doesnt charge the battaries it just holds the charge. but we shall see.
Old Oct 29, 2011 | 11:40 PM
Spurrit's Avatar
Replace cables and ends. Period. I replaced ends the other day; made a huge difference.
Old Oct 31, 2011 | 09:49 AM
JUST had the same problem. Mine was the cables. Just saying, over time, something to look at. I solved mine. I'm NOT an expert but, it may be a place to start on these old Hauses, from what I have heard. Post more questions or the outcome.
Old Oct 31, 2011 | 09:55 AM
Spurrit's Avatar
Anyone know of a place that stocks the cables for these trucks? The positive is a pain to find.
Old Nov 5, 2011 | 12:23 AM
mopwr2004a's Avatar
I have a 2007 with a bttery issue now. about a month ago I replaced both Batteries. tonight I used my trailer winch to load my car. So on the way to the track the volt gauge shows no charging. The truck started fine a couple of times. then on the way home I got a dash light that said check gauges. got hm shut the truck off and wldnt start back up. so I put my battery charger on the truck and one of the batteries started smoking and boiling over. when I replaced the batteries the one that was bad then was on the same side of the truck but this was before using a winch. is it possible I damaged the battery using the winch. even so why would the gauge not show the alternator charging.
Old Nov 7, 2011 | 01:45 PM
I got the dual battery positive cable at O'Reilly for $80-$90.
Old Nov 7, 2011 | 02:02 PM
Spurrit's Avatar
Thanks! Now, I need to find one for a reasonable price.
