Thinkin bout a 3in body lift on 99 dodge
Old Oct 10, 2011 | 08:52 PM
1999 Sport Cummins's Avatar
Default Thinkin bout a 3in body lift on 99 dodge
i wanna put a 3in body lift but i havent researched how my replacement bumpers would come out? any suggestions.. Id also like to see some pics of truck like mine with body lifts.
Old Oct 11, 2011 | 12:19 PM
coors_man_2005's Avatar
i wouldnt run a body lift on anything all there good for is breaking the body mounts and just look like crap imo bet others will agree just put a bigger suspension lift on you would be much happier
Old Oct 11, 2011 | 01:01 PM
Karls03's Avatar
With the fabricating involved (shift linkage, cooling system, brake lines, cab to chassis grounds, fuel filler neck, bumper relocation, etc), a suspension lift may be the better way to go.
Old Oct 11, 2011 | 06:08 PM
alright but i was going to put a 5in suspension with it
Old Oct 12, 2011 | 03:33 PM
1AMatt's Avatar
Site Sponsor - 1aauto
X2 There is a lot of little things that have to be adjusted. It is quite a pain! I like the idea of a bigger suspension lift
Old Nov 12, 2011 | 09:06 AM
95f2504x4's Avatar
Plus putting a body lift on it will raise the trucks center of gravity as you are lifting the body off the frame which makes it more top heavy.
Old Nov 12, 2011 | 09:10 AM
03Powerstroke's Avatar
Nice truck
Old Nov 12, 2011 | 09:38 AM
RAW's Avatar
RAW
How big of tire are you thinking of running?
This kit claims to fit a 37" tire.
KORE Recon Front Diesel
As for the rear, they have kits for that too. Air bags work well too.
Old Nov 12, 2011 | 09:34 PM
just throw 8 or 10 inch suspension look alot better and be done right that way your already buying the lift so why not buy a bigger one
Old Nov 15, 2011 | 10:27 AM
1AMatt's Avatar
Kore makes GREAT lift kits... The only problem is they are quite pricey
