falls on its face
Old Oct 10, 2011 | 05:17 PM
97 f350 p-stroke crewcab's Avatar
Default falls on its face
ill start my 97 f350 ill let it warm up. i have a 3'' down pipe and 5'' tail pipe ts chip on 50/75/100/140 hp settings at 2000rpms it falls on its face. little over 2500 it will get back and go. when its been running for away its fine. its has 257000 miles on it. i got the truck dont know what has been done be for me. it was a highway truck, towed from day one. need gauges. dont know if the guy ever did injectors. i knoe the guy ran amsoil it the trans and axles. any help is great.
Old Oct 10, 2011 | 07:31 PM
95powersmoker's Avatar
Does it set the CEL at all?
Old Oct 10, 2011 | 09:08 PM
nope it does a little on the stock setting but its really hard to tell
Old Oct 10, 2011 | 09:11 PM
Possibly a weak HPOP
Old Oct 10, 2011 | 09:16 PM
You need to get it on a scanner, You want to know what kind of condition the HPOP is in as well as injectors..
Old Oct 10, 2011 | 09:24 PM
no they make the ones that came with the truck new. ill try to call the guy i got the truck from. and i can use the HPOP for a super duty right?
Old Oct 10, 2011 | 09:27 PM
You could. But Before you start throwing parts at it. Diagnose the problem...
Old Oct 11, 2011 | 06:29 AM
I forgot to say if I'm driving it normal or like an old man its fine. Its only does it when in hard on the skinny petal.
Old Oct 11, 2011 | 07:23 AM
MossBack's Avatar
Default Re: falls on its face
If you still have stock fuel system then of course it will fall on its face up until 2500 when that poor mechanical pump is giving its all. I would also change fuel filter.
I change mine with every service and this sounds to me more like a fuel problem then hpop.
sent from my iPhone killer
Old Oct 11, 2011 | 09:26 AM
Again....
You need to get it on a scanner.....
Check your fuel pressure while your at it...
