TC seems like locking /unlocking
Old Oct 7, 2011 | 01:47 PM
Marine's Avatar
Default TC seems like locking /unlocking
Hi all,
I have a problem;
My truck has started what seems like the TC locking/unlocking. This happens when there is a lug (1200-1500 rpm). Mainly happens in 3rd gear I think after shifting from 2nd when RPM's are relatively low. Once RPM's are higher it doesn't seem to do it, but will also do it in 4th.
I did adjust the front bands to 80 in/lb in July but it did not start doing this until about 1 month after that.
Any ideas on what to do?
Thanks!
Old Oct 8, 2011 | 03:51 PM
cummin_un_glued's Avatar
FormerVendor
does it only do it around 45 mph?
Old Oct 9, 2011 | 01:08 PM
Marine's Avatar
It does it at any speed where the rpms are under 1500 and there is a little load on the engine.
Old Oct 9, 2011 | 01:40 PM
BACONBITSFORU's Avatar
Mine does it around 45 so I just do 50
Old Oct 11, 2011 | 08:57 AM
Marine's Avatar
Any ideas on this?
Thanks,
Old Oct 11, 2011 | 11:03 AM
DTT Noise Filter will fix this issue. Its caused by an electrical noise in the system. Its causing your TC to lock and unlock.
Luke
Old Oct 11, 2011 | 11:05 AM
Marine's Avatar
Luke,
but why would it start all of a sudden?
Thanks,
Old Oct 11, 2011 | 11:37 AM
I had my 01 for over 5 months before it started doing it. I unhooked the batteries and it would quit for about 2 days then start back.
Old Oct 11, 2011 | 11:43 AM
Marine's Avatar
I'll have to do that. I'll update what happens.
Thanks!
Old Oct 11, 2011 | 12:13 PM
Farmboy 2.0's Avatar
Yeah i think the DTT noise filter is kinda like the BD Diesel Apps noise isolator
