Catalyst Full Service Required
Old Oct 6, 2011 | 09:28 PM
dragrcr's Avatar
Default Catalyst Full Service Required
This morning catalyst full service required popped up on my overhead,but i have done all the deletes. I have the H&S mini max & has no codes. How do i clear this off my overhead. I read a post similar to this but the guy had a smarty. It said to disconnect all the batteries & touch the neg to pos post. Is this what i need to do or is there another way. Thanks in advance for any help.
Old Oct 6, 2011 | 10:31 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
you can try to clear it. i know they are no codes but just do it just like you got a code. i have to do that with my smarty.
Old Oct 7, 2011 | 12:40 PM
dragrcr's Avatar
Thanks Tony,I'll give it a try.
Old Oct 8, 2011 | 06:54 AM
yj junker's Avatar
I just go to a different display on the overhead when mine tells me that,it will go away but I usually have a good laugh,how the he!! does the truck know it is full when the pipes are in the shed
Old Oct 9, 2011 | 12:15 AM
dragrcr's Avatar
yea, couldn't help but laugh. there's nothin there. i've tried to get it off but nothin yet.
Old Oct 17, 2011 | 04:36 PM
OGFB555's Avatar
my truck said the same thing but this was before i had cleared the code, i have the edge race programmer and i have gone through and cleared the codes already but now every time my truck comes to an idle, my EGT's rise to about 750 and the turbo is wound really high. would yal know whats possibly causing this?
Old Nov 1, 2012 | 09:39 AM
Ron Heath's Avatar
What is cat full
Old Nov 17, 2012 | 09:00 AM
Rail's Avatar
Mine threw that message and two others, tried different downloads, reprogramming and then I think Chuck at H&S suggested it may need a fuel rail plug. I put one in and still had to do a complete download from scratch but the fuel mileage increased, runs smoother and no more big messages "get to the dealer now" or die coming over the console.
Old Nov 21, 2012 | 08:20 PM
CumNasty's Avatar
what version are you running. Mine was doing the same thing. Trouble is that its a "body" code and the tuner only scans dtcs from motor. Update tuner the new software fixes this problem. It did for me anyway on their site it tells you what new updaqte fixes and i believe in like julys update it specifies this problem
Old Nov 26, 2012 | 08:13 AM
Rail's Avatar
ah, geeze who remembers versions??? It was about June/July when H&S started down the path on me with this. Then I had a couple out of town trips with the "dinger" as I came to call it. Almost wore ear plugs it was every 10 miles! The latest on the website is the same one they sent me I am told for the Dodge 3500 specifically and I had to have it reprogram the engine not just update it, if that helps. Sorry dude it's 15 degrees out there and just don't wanna go look at the version. The fuel rail was blowing overflow and I think the plug did the biggest change. Though I did notice that getting rid of that 25lb CCV filter full of black crap made a big difference.
