number 7 cylinder
Old Oct 2, 2011 | 01:31 PM
dolla_hite's Avatar
Default number 7 cylinder
which side of motor is the number 7 cylinder/injector
Old Oct 2, 2011 | 03:00 PM
fordornothing's Avatar
passenger side. far back...
Old Oct 2, 2011 | 03:06 PM
dolla_hite's Avatar
thanks. thinking that number 7 injector wires are broke which blew the idm
Old Oct 2, 2011 | 06:35 PM
i'm not sure that a broken or loose wire would fry the IDM. in mine the UVCH came partially unplugged and it knocked out my # 1&3 injectors but plugged it back in and it's fine.
Old Oct 2, 2011 | 07:11 PM
95powersmoker's Avatar
Maybe some more information here would be helpful....
Old Oct 2, 2011 | 07:41 PM
i'm thinkin so. if the wire completely broke in two and shorted, then it could fry it, but even then that's not very likely.
Old Oct 2, 2011 | 07:44 PM
dolla_hite's Avatar
idm went out. got new one runs but hickups when you get on it i believe(dads truck not mine) mechanic hooked up scanner and said #7 injector open circut.
Old Oct 10, 2011 | 07:54 PM
dolla_hite's Avatar
ok i wondering if anybody knows which prong on the plug that plugs into the idm is the number 7 injector. does that make any sense?
Old Oct 10, 2011 | 07:59 PM
ahhhhhhhhhhhh. get a battery and a test light. look at the wire color for the no 7 and it might be the same...
Old Oct 10, 2011 | 08:08 PM
dolla_hite's Avatar
ok ill tell my dad to try that and see if he can tell.
