IP
Old Oct 1, 2011 | 10:24 AM
billiard's Avatar
Default IP
I've got a 1984 250 with the stock 6.9 in it. I feel like a rebuild of the IP would help the truck run a bit better. I've got the screw turned up a flat down from max. When I had it all the way up occasionally when id come to a stop the idle wouldn't come down until I put it in gear and let out the clutch. And it also kind of rev up itself as im driving with my foot steady of the throttle and buck pretty bad when downshifting. Im pretty sure these are all signs of overfuelling which im certain I am but before I turned it up it was doing the not revving down issue, everything just got worse.
Im thinking if I get the pump rebuilt ill have better luck with a fresh ip. When I got the truck a year ago the pump timing was retard probably 10 degrees and it ran terrible and the tamper seal is cut so who knows where the fuel screw is at if they already have already been messing with things. Im looking for onions on if I should get it rebuilt or maybe better placement of the fuel screw and if there is anyone on here around my area that could rebuild it at a good cost.
Old Oct 1, 2011 | 01:35 PM
DieselCrawler's Avatar
how many miles are on the pump? also check your throttle cable for binding, the plastic can break off near the pump linkage and bind up the cable.
Old Oct 2, 2011 | 08:51 AM
billiard's Avatar
The cable isn't binding anywhere that part of it works great and im not too sure how many miles are on it. The odometer says 93,000 but it could be 193,000 or 293,000 or more but I doubt that
Sometimes although it hasn't happened in a while but sometimes it wont shut off when you take out the key you have to stall it to kill it
Old Oct 2, 2011 | 01:39 PM
time for a reman pump. stay away from pensocola.
Old Oct 2, 2011 | 02:46 PM
billiard's Avatar
Do you recommend anyone to rebuild them?
Old Oct 3, 2011 | 05:08 PM
oregon fuel injection is good. DPS you can take your chance with. they are hit and miss with their rebuilds.
Old Oct 5, 2011 | 04:26 AM
4x4manonbroke's Avatar
i know of a local company here in milton washington called B&B diesel they do a wonderful job and they will flow the pump before and after and they do injectors also
they did mine and damn it runs awesome gettin 18 mpg @ 65 mph (2400 rpm's) all day
another problem i ran into was the fuel water sep. bowl on the bottom.... get rid of it ....
im running a Baldwin filter # BF1222 works great and its not sucking air anymore..... I had the same problem..... cheeper than a pump .... start with the small stuff and work your way up
Last edited by 4x4manonbroke; Oct 5, 2011 at 04:26 AM. Reason: Automerged Doublepost
Old Oct 5, 2011 | 06:21 PM
84 doesnt have that style FW seperator.
Old Oct 30, 2011 | 12:22 AM
Spurrit's Avatar
[color=grey][size=-2]
How much do they charge?
Old Oct 31, 2011 | 10:21 AM
Sandman8105's Avatar
DC,
I was told my motor was rebuilt at 120K but, I doubt it because of the problems that you have heard about it,and the valve cover bolts were loose as hell! (Have documentation of it but, any shop can write one for a price). As far as I am concerned, (odometer reading) just went over 200K. Time for an IP rebuild?
