my diesel will not start...HELP
Old Sep 24, 2011 | 12:50 PM
PONCER's Avatar
mad my diesel will not start...HELP
THREE DAYS AGO I MOVED MY TRUCK FROM ONE SIDE OF MY YARD TO THE OTHER. TRUCK HAD BEEN WORKING FINE BEFORE, WHEN I WENT TO GET IN IT TODAY, TRUCK WILL NOT START.! CRANKS OVER BUT WILL NOT START...I HAVE CHANGED FUEL PUMP, INLINE FUEL FILTER AND FILTER IN ENGINE AREA IN PREVIOUS MAINTENANCE THAT I HAVE DONE ON MY TRUCK WHICH WAS ABOUT THREE MONTHS AGO...STUMPED.!
Old Sep 24, 2011 | 01:15 PM
captain_stabbin's Avatar
hmmm
Old Sep 24, 2011 | 01:25 PM
03Powerstroke's Avatar
idm?
Old Sep 25, 2011 | 03:18 PM
fordornothing's Avatar
possibly CPS.
Old Sep 26, 2011 | 12:44 PM
CSIPSD's Avatar
Best bet would be to pull codes and go from there... Not sure why you would replace the fuel pump, pissed away $150 bucks on that one for nothing.
Old Oct 1, 2011 | 08:37 PM
NeedinMoPWR's Avatar
maybe a stupid question but how are your batteries? have you tired to jump it?
Old Oct 1, 2011 | 09:03 PM
Powersmokin32's Avatar
Default my diesel will not start...HELP
Your not getting high pressure oil. Probably bad HPOP not uncommon to see. If it will start cold u have a leak if not then your pump is bad. And im sure its not leaking as you said it sat for a few days before starting.
Old Oct 1, 2011 | 09:06 PM
CyleMik's Avatar
check the cps and the batterys if your not getting right voltage the truck wont start i know it sounds funny but try it. also did you try to plug it in?
Old Oct 1, 2011 | 09:09 PM
I have driven my 7.3 with the alternator out and the voltage at around 8 or 9volts.
Old Oct 2, 2011 | 08:36 PM
CSIPSD's Avatar
Nothing in what he posted tells me he is not getting HPO...
