fuel line replace
Old Sep 23, 2011 | 02:45 PM
flathead jack's Avatar
Default fuel line replace
well here it is 1.remove positive battery cables lay something thick and soft over radiator 2 remove all hoses to heads and intercooler from y pipe . 3 remove all connections to y pipe remove y pipe lossen bolts on solinoid bracket and lift it up as far as you can. 4 remove fitting from fuel bowl then remove from back of head remove line clamp from head in back of y pipe 5. you can now remove the line. 6 when installing new line start fitting on back of head first then start fitting in fuel bowl when tightening fitting be sure to keep line pushed into fitting as far as it will go 7 then reverse procedure. it took me 3hrs and i looked like id been in a knife fight but worked fine. hope this will help some one when it happens to them by the way it rubbed into at the line clamp on the head. be sure to wrap the line at the clamp so it wont do it again.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
|WYG|SS
May 7, 2015 04:57 AM
moneypitk5
Feb 12, 2015 11:01 AM
Dec 5, 2014 08:30 AM
