IDM Codes
Old Sep 22, 2011 | 03:53 PM
Team01's Avatar
Default IDM Codes
Hi I have a 1999 Ford F350 Super Duty 4X4 with 7.3 deisel w/ turbo. The truck is running rough and had a for tech look at it. He told me that it was not firing on 1 and 6 and to check all the wiring and if the wiring was ok it had to be the IDM. I checked the all the wiring under the valve covers and connections and they were all ok. I replaced the IDM with a recondition one and know i get a code P1316 Can someone Please help me with this problem.
Old Sep 22, 2011 | 07:13 PM
fordornothing's Avatar
P1316 Injector Circuit/IDM Codes Detected
Did you pull the valve covers? or just where it plugs into the gasket? check the main plug on the drivers valve cover, it's a 2"x 2" plug with a 10 mm bolt. make sure it's tight. my pickup did this and the UVCH was partially unplugged from the gasket on the inside.
Old Sep 22, 2011 | 09:12 PM
Team01's Avatar
I pulled the valve overs and checked the wire connections to the injecters and glow plugs. The main wire plug on the drivers side it tight
Old Sep 23, 2011 | 05:13 PM
ok so all connections are tight. have you had a buzz test done on it?
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Renowest48
Dec 14, 2014 08:36 PM
Altonlee
9
Oct 8, 2014 02:31 PM
