Early 99 no oil pressure in hpop reservoir!!!
Old Sep 21, 2011 | 09:41 PM
broncocarnage's Avatar
Question Early 99 no oil pressure in hpop reservoir!!!
ok the other day i was driving along and noticed my op gauge on the dash drop to 0 and the dummy light came on.. me knowing the truck wont run with out op drive home. i replaced the op gauge switch and still read zero so i put a manual gauge on the hpop res. and started the truck, it stays at zero... im at a loss here on this thing. i have changed the oil and filter thinking maybe the filter collapsed and it still reads zero. if i rev the truck up to 2k it reads 5 psi but anything below that its at 0, idk what to look into from here. all info is greatly appreciated. TIA!
Old Sep 21, 2011 | 10:07 PM
CSIPSD's Avatar
Sounds like a broken LPOP...
There is another port down by the oil filter, check the pressure there.
Old Sep 23, 2011 | 01:29 AM
99xlstroker's Avatar
does the truck run and drive at all. the truck needs 550 psi mini output from the hpop to even start
Old Sep 23, 2011 | 05:09 PM
fordornothing's Avatar
well testing pressure from the plug on top of the HPOP resivoir is pre HPOP. so if the resivoir isn't even getting oil how can the HPOP get oil to the injectors? i'd say LPOP.
Old Sep 24, 2011 | 12:44 PM
i checked the lpop this am and it only has 10 psi at idle and if i revv it the op will clime with the rpms to 40lbs at 2k rpm..
anyone have a oilflow chart?
Last edited by broncocarnage; Sep 24, 2011 at 12:44 PM. Reason: Automerged Doublepost
Old Sep 24, 2011 | 01:14 PM
look around on this site. there might be one some where.
Old Sep 25, 2011 | 12:24 PM
ok i changed the lpop and nothing changed???
Old Sep 25, 2011 | 03:03 PM
hmmm. there was a similar post on this site a while back. on the inside of the front cover there is a plug that actually fell out causing the no oil pressure problem. that post was on the old bodies tho. but it could be your problem. but don't quote me on it.
Old Sep 25, 2011 | 04:11 PM
found a broke rocker arm
Old Sep 25, 2011 | 04:21 PM
well that's a problem. how many miles are on the truck?
