Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Truck feels like it doesnt want to go anymore
Old Sep 21, 2011 | 07:53 PM
DMax6600LBZ's Avatar
Default Truck feels like it doesnt want to go anymore
i hav an lbz duramax. im running an edge evo programmer, an aftermarket drop in air filter, and an mbrp turbo back exhaust. i turn my programmer all the way up and i punch it, the truck will throw u back in the seat for a while, but then lets up and feels as if its bogging down. i thought it was the air filter so i changed that and it didnt help. maybe not enough fuel? any ideas?
Old Sep 22, 2011 | 11:12 PM
BriteWhiteRam's Avatar
Edge has safeties built in to keep you from hurting the truck, it will back down if EGT, boost, engine temp, trans slip exceed the set parameters, Im not entirely sure if the evo is the same as the juice, but I assume it is, if thats the case you should look in your edge manual to see if you can change those parameters, I know I could with my juice/attitude
Old Sep 22, 2011 | 11:41 PM
2500HeavyDuty's Avatar
at what speed does it do that?
Old Sep 23, 2011 | 11:32 AM
Budgreen's Avatar
sounds like defueling to me.. the EVO will defuel on high EGT's
also.. check the speed limiter setting in the custom option menu. after mine was all updated i found it set at 90mph
Old Dec 22, 2011 | 10:13 AM
fox2boost's Avatar
fuel filter clogged?
Old Dec 22, 2011 | 10:21 AM
MillerBoyzDiesel's Avatar
id check fuel filter, have you turned your edge off and checked if the problem still occurs?
Old Dec 22, 2011 | 12:12 PM
Budgreen's Avatar
transmission limp?
doublehbar
13
Aug 9, 2015 12:35 AM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
