93 cummins wont boost past 14 psi
Old Sep 13, 2011 | 12:51 AM
94CumminsBronco's Avatar
Default 93 cummins wont boost past 14 psi
Ok well. I want to start a project thread here but I've not had the time to do a full write up as I've been working past 1am everynight after work at 5 to get this beast running. Which it does now.
First off ill start by saying im not a complete newb at turning wrenchs I've done many crazy engine swaps but this is my first ctd. What I have is a 94 bronco on all f350 drivetrain with a cummins 93 ve engine swap.
Here is my problem I messed up somewere not sure were. Current mode are the 3200 rpm governer spring, dennyt stage2 fuel pin, and a hx40 6 blade(figured it was still a improvement), 215 injector nozzels, full 4 inch exhaust. Got it running tonight and filled it up let it warm up went out and jumped on the throttle. 14psi that's it.
I thought maybe it was because the pump star wheel, full fuel enrichment screw,and smoke screw were never modified. I was thinking not enough fuel = not much boost.
I turned the smoke screw 2 full rotations clockwise, turned fuel rod 2 turns(by the way the tamper clip was a pita and turned star wheel 8 clicks. Lights up alot faster but still 14psi.
I thought maybe wastegate was only set for that so I temporarily pinched the line closed, 14psi still, wired the gate closed 14psi still!
The only thing I can figure tho I don't think its the problem is when I did the spring install I didn't mark or write down the indexing.... :-( so I moved the throttle to just were it idled normally and tightened it all down.
I also probably made a mistake by doing this all at once not in steps. Any help would be amazing thank you in advance.
Also egt never gets past 7-800
Last edited by 94CumminsBronco; Sep 13, 2011 at 12:51 AM. Reason: Automerged Doublepost
Old Sep 13, 2011 | 07:43 AM
NadirPoint's Avatar
Obviously not getting fuel. Does it run right for 14psi- no sputtering or miss?
Old Sep 13, 2011 | 07:51 AM
Kraemer's Avatar
if its a factory hx 40, I believe they have a 16mm clearance exhaust housing, you need alot of fuel or a smaller exhaust housing
where are you measuring your egts?
Old Sep 13, 2011 | 09:05 AM
It is a 6 blade hx40 from a 8L cummins.
The egts are measured from the front runner on the manifold.
It seems to spudder/miss a little since a turned the power screw in. But I was kind of thinking it was just high idle. Which I've yet to adjust back down
Under wot runs great no spuddering. Not sure what else to check.
Last edited by 94CumminsBronco; Sep 13, 2011 at 09:08 AM. Reason: Automerged Doublepost
Old Sep 13, 2011 | 09:13 AM
NadirPoint's Avatar
I would try indexing the throttle shaft 1 spline counterclockwise and check your fuel supply/pressure/filter. You should have plenty of fuel with those injectors.
Old Sep 13, 2011 | 09:24 AM
Counter clockwise raised the idle pretty high. But on that note I never ran it since I did the fuel pin install, not sure if they raise idle too?
Old Sep 13, 2011 | 09:30 AM
NadirPoint's Avatar
Is there any adjustment to turn it down with the stop screw? Also, make sure the throttle is getting full travel. Sometimes they will stop on the fuel inlet line if you don't clearance it a little, or possibly the linkage/cable is not tight.
Old Sep 13, 2011 | 01:57 PM
The throttle goes all the way both directions. Had to pit a assist spring to help pull it down tight against the idle screw tho.
Ill try to index it again after work. Thanks again for all the help
Well went ahead and tried to move it CCW and CW on the splines, No diffrence, CW won't run, CCW idles extremely high and still only 14psi boost.
Fuel filter is brand new, fuel lines are all brand new..... More ideas?
Last edited by 94CumminsBronco; Sep 13, 2011 at 01:57 PM. Reason: Automerged Doublepost
Old Sep 13, 2011 | 02:48 PM
NadirPoint's Avatar
Does the throttle go all the way from the accelerator pedal?
Double check the wastegate and make absolutely sure it is closed tight.
Fuel pressure? Idle and WOT....
I'm just about out of ideas.
Old Sep 13, 2011 | 03:23 PM
Lever goes alllll the way on the pump from the pedal, checked that first thing.
I've gone as far as completely REMOVING the wastegate and tieing it closed. (closed off the port on the compressor housing also)
I've not yet checked fuel pressure from the lift pump, I kinda figured it would be working just fine seeing as it had no problems in the 1993 dodge, BUT then again, that was also a stock truck with over 200k on it. So maybe the lift pump is weak? I don't assume a helper electric pump is needed on these things.
I thought even maybe the aftermarket air filter was to small and went as far as taking it off and running it down the street thought maybe it was to restrictive. But that wasn't it either, I'm LOST..
When I first jump on the throttle it get a nice puff of black smoke, then CLEAR... Like no fuel which is i'm sure why the turbo isn't spooling...
Do people typically just close the wastegates on these turbos or just run a straight line from the compressor to the waste gate (wastegate boost)
I've build a few DSM's and a couple 4ktq and other turbo cars in the past which obviously use a boost controler of some short.
What should the lift pump PSI be? I'll check that in a hour or so. Maybe its not pumping enough anymore... I'm sure its original.
Last edited by 94CumminsBronco; Sep 13, 2011 at 03:31 PM. Reason: Automerged Doublepost
