06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
diablo sport extreme power puck????
Old Sep 12, 2011 | 04:32 PM
Duramax07's Avatar
Default diablo sport extreme power puck????
Hey everyone i have a 2007 classic LBZ with 5"mbrp strait pipe, airbox mod with K&N drop in filter, and the PPE standard on the 90hp setting (60whp). i do not want to turn my PPE up to the 160hp (112whp) setting becasue that is the next step up and is not the best idea for a stock tranny and cp3. So my question is has any one used the power puck on there LBZ with good results?. im not out ot buy it and crank it all the way up, as you can see i am wanting to stack this with the ppe standard on 90hp(60whp) setting, maybe only adding 25 to 30 more hp nothing major just a little more safe hp, that is all i am NOT going to max it out ever unless i invest in a cp3 and tranny. and information like pros/cons about it would be helpful. or some one who has a reason they stand against it please let me know why!
thanks for the help
Old Sep 13, 2011 | 06:51 PM
BriteWhiteRam's Avatar
I say no to stacking, you dont know what either unit is doing for fueling, injection timing, etc.
If it were me, and I wanted more power I would get a transgo Jr. installed and run the 160hp tune on the PPE, that way you only have one tune thats doing everything, I hate the idea of mixing power adders
Old Sep 13, 2011 | 08:34 PM
Transgo Jr Kit and a Triple Disc Converter will make a BIG difference.
Luke
Old Sep 13, 2011 | 08:45 PM
Duramax07's Avatar
-see i do agree with you and saying probably better off running the 160hp tune but i do not want to spend the money on the transgo Jr. and i hear you have to drop the tranny to install it
-and the thing is this extreme power puck would be nice to have in the future after a tranny and cp3 would be installed. this power puck is basically a dial like dsp5 but turns in a complete 360 stopping at the bottom (mid point being strait up or 50hp) because all the way truned is 100whp. the reason i would like this is because i can add another 25whp to my 90hp (60whp) tune so im only at 85whp not all the way up to 112whp (in ppes 160hp tune). from my knowledge this power puck installs to the fuel pressure regulator and the map??? or something like that so the father the switch is turned the more the map and fuel is changed. And this is nice bacause it can be done on the fly!!!
-as i have said i would not even use, manily just daily drive on the 90 hp ppe setting and when i want another 25whp, just turn it up a little and ruturn it back to the zero setting or resting point. as i have said before im not stupid and know there are limits and would never even pass much more then 25whp, and this would be very uncommon for this to even happen.
-if there is anything you know about the extreme power puck that i havent said please let me know thanks "britewhiteram" you have helped me before
what would it run me fro transgo jr. and a triple disk converter run me to buy them and install.
Old Sep 14, 2011 | 10:15 PM
The transgo jr. from Merchant is $100
http://www.merchant-automotive.com/a...rshiftkit.aspx
and you don't have to drop the trans to install it, just have to pull the valve body and drill a couple holes bigger
If you want that power on the fly sell your PPE and save the cash you would spend on the Powerpuck and buy EFI live with a DSP5, I HATE stacks... HATE!! they aren't needed when you have better technology available!
Old Sep 15, 2011 | 09:42 AM
Duramax07's Avatar
thanks britewhiteram i know you have helped me before on other questions i had before.
my question is what does that transgo jr. do? why is it better then what i have now and does it really help? And also how long would it take a guy and his buddy to install... Im only 19 but i am mechanicaly in tune if thats how i should describe it
Also does this require me to drop the tranny pan? do i need to replace the gasket? i will prob fill her up with amsoil.. if im able to.
Old Sep 15, 2011 | 07:43 PM
the transgo just helps to sharpen shifts, it helps to hold a little more power than stock, you could run probably a 425-450rwhp tune with the transgo jr.
You do have to drop the pan, and im not sure on the gasket, sorry, but it should be easy enough for you and your friend to do, as long as you keep everything clean, and follow the instructions
Allison's recommended fluid is Transynd, I would use that before amsoil
Old Sep 15, 2011 | 09:29 PM
Duramax07's Avatar
alright your not a strong believer in amsoil?... and i think i have decided to go with efi live as we have talked about before i can get it for dirt cheap from a friend.
Old Sep 17, 2011 | 08:46 AM
I'm just saying that Allison's top recommended synthetic oil for the A1000 is Transynd, its extremely high quality oil
Old Oct 25, 2011 | 07:10 PM
DirtynessMaximus's Avatar
transgo jr puts more pressure on the torque converter, which gets you better shifts.
