6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Will 285's Fit On Stock Dually
Old Jan 6, 2008 | 08:34 PM
TEXASPOWER's Avatar
Default Will 285's Fit On Stock Dually
ive got 2 inch spacers for the rear but will they clear up front without a leveling kit
Old Jan 6, 2008 | 08:39 PM
2500HeavyDuty's Avatar
I don't think so, there will be rub. Ive heard that the NBS cant clear bigger tires as well as the OBS, and mine rub back out the driveway with my wheels locked to the sides
Old Jan 6, 2008 | 08:52 PM
DangerousDuramax's Avatar
Danny, on yours you need to crank your bars, tie back the fender liners, and trim the front valance. I've got 32.4" tall 285's and mine don't rub even off road.
Old Jan 6, 2008 | 08:56 PM
It rubs when i drive off the ledge with wheels at lock. and it barely even noticeable. I might put in my green keys after i get a new center link and pitman arm
Old Jan 6, 2008 | 08:57 PM
TEXASPOWER's Avatar
this is on an 05 ford 4x4 but i know they would on an 04 with the leaf springs in the front end, but its a coil over or wat ever u call it on an 05 didnt know if they changed the hieght any
Old Jan 6, 2008 | 09:00 PM
this is in the ford thread. You should have no problem then
Old Jan 6, 2008 | 09:05 PM
Danny, you don't need green keys. For what you are wanting to do you have plenty of crank with the factory bolts and keys.TP I'm not sure about the Ford but maybe Brant can post an answer.
Old Jan 6, 2008 | 09:06 PM
DazedandConfused's Avatar
Yeah I clear 285s on my 2wd dodge with little coil spacers.
Old Jan 7, 2008 | 12:41 AM
Blue01F250's Avatar
Duramax Virgin
I'm 95% sure that they will clear -- I'm going to put some on my 2wd... its once you get to 295 and larger that you start to have problems
Old Jan 7, 2008 | 10:12 PM
LOGANSTANFORTH's Avatar
they will fit......you can fit 35's on a SD with just a 2 inch leveling kit.....
