overharting lb7 2004 duramax
Old Sep 6, 2011 | 05:49 PM
unclecowboy's Avatar
Default overharting lb7 2004 duramax
i have an overheating problem with my truck it had a leaking water pump so i changed it and ran it about twothousand miles before any trouble, i had to take my daughters to a rodeo,i was pulling a very steep grade and smeld antifreze but no smoke the temp dint go high or the trans temp high ,i made another fifty miles and the low coolant light came on so i pulled over and checked it looks like the new pump has started to leak around the bottom of the pump and it is makeing noise like a crank bearing ,i hauled it home to the shop and started diagnosis the coolingsystem is building pressure in it slowly there is no water in the oil it seeems to have more blowby with the oil cap off and it builds more pressue in the cooling system when i pump up the cooling system to 15 psi with the cooling system hand pump when it has no pressure pumped in it will make a negative vacume when you throttle up then on decel of the motor it sucks a vacume on the gauge any help i need this truck for work and transportation and hoped that someone has had to deal with this please help thanks
Old Sep 6, 2011 | 05:53 PM
mysterync's Avatar
Default Re: overharting lb7 2004 duramax
Exhaust gases present in cooling system?
Old Sep 6, 2011 | 06:05 PM
i cant smell any but i would guess that there are with the pressure tester gaining and sucking vacume at start up i havent seen one ever suck vacume then build presure there arent any leaks when i pump it up to 15 psi, but it builds really fast past the top end of the gauge when running it at 3000 rpm and 15 pounds pumped up in the colling system thanks for your help
i think i can smell exhaust gasses in the oil fill tube my luck its probly a slipped sleeve hope not
Last edited by unclecowboy; Sep 6, 2011 at 06:05 PM. Reason: Automerged Doublepost
Old Sep 6, 2011 | 06:29 PM
mysterync's Avatar
I would invest 60 bucks in a combustion leak detector. If so I would start with compression/leak down testing to verify location of leak. I really prefer compression then leak down on low cylinders. Considering it appears to be cooling system related I would bother with a wet compression
Old Sep 6, 2011 | 06:46 PM
i have a compesson tester ill start there thankyou so much then ill post the results as to what that says thanks again
Sep 7, 2015 07:30 AM
Bamafantrey
Chevy/GMC Duramax 01-04 LB7
Aug 24, 2015 09:30 AM
Oleoleson
Mar 28, 2015 06:20 PM
Nick3093
10
Mar 22, 2015 09:46 AM
Shadow644
Potential Diesel Owners Forum
Feb 5, 2015 07:48 PM
