erratic low oil pressure
Old Sep 4, 2011 | 12:32 AM
muddyold7.3's Avatar
Default erratic low oil pressure
my idi has started to show low oil pressure at idle or when im breaking and get to around 25mph not throttle itll jump around when its warming yp but eventually when im not on the throttle and under 25 its at the bottom of the gauge reading no pressure i replace the oil filter and its good for about a day to a week then starts acting up same with when i change the oil which when i do that of course i do the filter could it be my bypass valve or oil pressure regualtor valve how hard is it to replace these is it pricy...i would just hook a mechanical gauge to my truck but the sending units right underneath my turbo any feedback or help would be much obliged thanks
Old Sep 4, 2011 | 07:45 AM
DieselCrawler's Avatar
install a mechanical one. the factory gauges SUCK to be blunt. you can get oil psi from other locations. one you can put a T at the top of your turbo where the line comes in.
here are some other oil ports.
Old Sep 4, 2011 | 06:59 PM
ten four im puttin a T on it today hope its just the gauge
oil pressure is real low once it warms up it runs under 5 psi does anybody know were to buy an oil pressure regualtor cant find anywhere
Last edited by muddyold7.3; Sep 4, 2011 at 06:59 PM. Reason: Automerged Doublepost
Old Sep 4, 2011 | 11:00 PM
will need to replace the entire rear head of the oil cooler. the bypass valve is located inside the head. non servicable.
Old Sep 6, 2011 | 02:47 PM
how much you reckin an oil cooler will run me
Old Sep 6, 2011 | 04:42 PM
new oil coolers are expensive. i belive you can buy just the heads of them. IIRC the heads are around 150 bucks or so.
Old Sep 6, 2011 | 09:02 PM
i think ill just go and grab one from the yard but i got no idea what this thing looks like or what it does
Old Sep 7, 2011 | 04:41 PM
here is my write up on oil cooler reseal. the rear head( where the oil filter screws onto) is where the oil bypass is located. if you get a new cooler from a yard, make sure you rebuild it first. will cost ya about 40 bucks or so for the orings and is cheap insurance. dont want to have to pull the cooler twice. it isnt fun.
https://www.dieselbombers.com/ford-8...er-reseal.html
Old Sep 8, 2011 | 11:50 AM
can i just rebuild mine?
Old Sep 8, 2011 | 04:58 PM
issue will be is it will still have the same bypass valve.
