injectors
Old Aug 31, 2011 | 01:16 PM
1989w250's Avatar
Default injectors
What are some cheap injectors that will boost my hp and still be cost affective im on a tight budget
Old Aug 31, 2011 | 01:49 PM
jdbigblue12v's Avatar
try prince of darkness others call them PODS
Old Aug 31, 2011 | 04:59 PM
RSWORDS's Avatar
Not on a non-I/Ced truck. The POD's are not much of an improvement at all. What little advantage they have in size over the stocker they give up in crappy patterns. Good stock non-I/Ced injectors should carry you to 350-175HP... 400 if you have a perfect tune but I mean PERFECT. I would not waste money on POD's.
I'm running some 435's rigt now in my 92. I had 6x16's in my 89, they made good power but were VERY smokey and needed ALOT of timimg to make them come alive. I would recomend 435's to anyone.
Old Sep 7, 2011 | 11:31 PM
jkidd's Avatar
Stock Non-IC are 155* Spray
POD are 150*
IC 91.5-98 are 145*
Stay with stock so you can avoid 7mm-9mm conversion washers and often a poor match of injector spray/cylinder bowl.
If you want 155* 7 hole I can get them to you.
Old Sep 8, 2011 | 12:34 PM
t-bone117yamaha's Avatar
i want to do bigger injectors on my 91 dodge i believe it has the smaller injectors because turn up the **** off screw and full power and i hardly get anything power wise so whats best for an ic 91 cummins with strait pipe cold air intake and minor pump mods?
and a tight budget?
Old Sep 8, 2011 | 01:24 PM
jkidd's Avatar
So this is for a 1991 Intercooled? What are you doing for a turbo? There are 40HP options that are still pretty clean, Also a 5x.012 will give a good amount of flow increase, but a turbo upgrade will be in order.
Old Sep 8, 2011 | 02:17 PM
i have the stock turbo and i want bigger injectors and would like it to smoke when my foots in it but be just haze at other times so not too much smoke
and im also on a strict budget like $500
what kind of budget turbo upgrades are out there?
Last edited by t-bone117yamaha; Sep 8, 2011 at 02:17 PM. Reason: Automerged Doublepost
Old Sep 8, 2011 | 08:11 PM
RSWORDS's Avatar
An HX40 with teh 16cm housing (<-- Must be 16cm if you want it to run right) is probably the best budget turbo upgrade. You gonna need to upgrade your budget though if you want good injectors and a decent turbo
Old Sep 9, 2011 | 12:05 PM
cool thanks and the $500 is just for injectors if im gunna do the turbo too i would probably hope for no more then $1000
Old Sep 9, 2011 | 08:04 PM
fatirishguy's Avatar
Hey it,s been a while for me. I would also like to know best injectors and turbo upgrade? you know smoke when on it hard but just haze when driving like a grown up.
