No power or smoke!
Old Aug 30, 2011 | 01:21 PM
MechanicalDiesel's Avatar
Default No power or smoke!
Got no fuel plate the truck barely has power, it struggles up hills and only hits 23psi. Barely smokes off the line even when i want it to is almost like still being stock. Checked ofv and thats fine, i dont hear any boost leaks. It starts up fine and my soleinoid is lifting fully. What could be my problem here. It also is rough at idle. The truck shakes a lot. It only started having a rough idle with my new tc. Whats going on with it?
Old Aug 30, 2011 | 02:05 PM
H.R.D's Avatar
If is started after you put the new TC on, I would start there maybe a bad converter.
Old Aug 30, 2011 | 06:40 PM
So how does my torque converter affect my smoke? It deffinitly puts more power to the ground compared to my stock converter. Could I have a dirty injector? or maybe air getting in my fuel? even before the converter change my stock wasnt very fast or strong as I thought it would be when i bought it. That even struggled up hills and barely smoked. I have a fuel leak but only when i shutoff my truck, and it leaks from a banjo on my fuel filter????? Maybe that will ring a bell with someone because im lost
Old Aug 30, 2011 | 11:10 PM
H.R.D's Avatar
If you have fuel leaking out then air is getting in. So I would fix that and see if that helps you. There are several things you can do, get the injectors pop tested. Run some injector cleaner through them, change fuel/air filters. You can do a valve slash. Those are all things you can do for cheap that can improve performance.
Old Sep 2, 2011 | 10:12 PM
RanchhandTCR's Avatar
IS your exhaust white? usually when you have rough idle its injectors thats my two cents.
Old Sep 6, 2011 | 07:36 AM
Well there is some white smoke at start up, but over all there isnt much white smoke when driving if any.
Old Sep 7, 2011 | 11:54 PM
Ya once it warm and you still got some white smoke I bet its injectors if not what the other guy said.
Old Sep 9, 2011 | 06:39 AM
Could the torque converter really cause this? Because I cant see how that would effect my truck, its seemed to be slow since i bought it, even before the new tc i had the stock tranny with a #8 plate and saw no difference. I am lost I really dont wanna buy a new tc
Old Sep 9, 2011 | 07:25 AM
mysterync's Avatar
Default Re: No power or smoke!
Is your afc working? Timing slipped? Gov springs ?
Rough idle could be vibration, might check your bolts and flex plate. Check fuel pressure and pressure drop at wot.
Old Sep 9, 2011 | 08:36 AM
I believe my afc is working, im getting 23 psi of boost max right now until i get a boost elbow. Timing could be the issue ive never check or done my timing. Also i havent installed my gsk yet, but i do got the 60lb springs in. Maybe it could be timing, or even my afc? How do i check to make sure the afc is working?
