P000F fuel overpressure activated
Old Aug 24, 2011 | 01:22 PM
familyman's Avatar
Default P000F fuel overpressure activated
I've seen some other threads on here about this being the fuel pressure relief valve or a sensor. What is does is regular throttle is fine but when I punch it right after the turbo kicks on I lose power and after I do that a few times the check engine light comes on. I don't run any power boosting equipment, it is just stock and I don't want to change that. I've seen things about replacing the valve with plug but I don't want to break something else more expensive either. I've also seen shim kits used. What is most likely the problem with this? Any ideas, recommendations please?
Old Sep 4, 2011 | 01:53 PM
aberube's Avatar
I have read: probably ECM programming, Cummins part (link to CAT). I would recommend shim kit. you won't release pressure with a plug kit.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
