98 6.5 TD Idle hunting problems!!!
Old Aug 18, 2011 | 08:59 PM
cornwejf's Avatar
Default 98 6.5 TD Idle hunting problems!!!
Well, I am at a loss of words... here is what I am dealing with...
Today I was driving my truck, 98 K3500 w/ brand new (less than 2500 miles) motor, I/P injectors, whole 9 yards. I replaced everything a month ago. It was running beautifully. I pulled into a station to filll up. Filled up and when I started the truck back up the idle was going from 600 RPMS to around 2000 RPMS, back and forth, back and forth. When I step on the pedal, no response at all. There is no check engine light or anything and I am smoking like crazy (white smoke initially then turns black when it goes up to the high end of the reving). When I shut the motor off it starts up, but as soon as I give it any throttle, it goes back to reveing between 600 - 2000 again, and the throttle is again unresponsive...
What do I check first? Any ideas. It is a brand new PMD, replaced with a fresh rebuilt IP.
I havent trouble shot at all because I have no idea where to begin. Any help would be a Godsend. Thank you.
Old Aug 18, 2011 | 09:20 PM
chummins89's Avatar
I'm no expert , but it sounds like the electronic throttle is not performing correctly , especially since you've replaced everything else.
Old Aug 18, 2011 | 09:38 PM
2MuchJunk's Avatar
Sounds like the i/p is bad. There is a valve inside the i/p I can't remember what it is called that goes bad and causes this.
Old Aug 19, 2011 | 01:13 PM
cornwejf's Avatar
Well, it is a freshly rebuilt IP. It should still be under warranty, but I want to make sure of what it is before I go saying it is a bad IP. Is the electronic throttle separate from the IP, or is it built into it? I need a way to troubleshoot this without just buying new parts.
Any suggestions?
Old Aug 21, 2011 | 03:27 PM
cornwejf's Avatar
Anyone else have any ideas?
Old Aug 21, 2011 | 04:10 PM
wildbill's Avatar
Injection pump. I been there done that several times with the 5.7 Olds diesel.
Dbleo351
Nov 20, 2016 09:34 AM
Jake202
Jun 21, 2015 09:42 PM
moroza
Mar 29, 2015 05:37 PM
carid
Diesel Bombers Sponsors
Feb 2, 2015 09:24 AM
Snoobly
Dec 11, 2014 11:59 AM
