PPE Boost Valve
Old Aug 16, 2011 | 07:22 PM
dreese's Avatar
Default PPE Boost Valve
Would I be able to put this on my truck it is stock. Would I notice anything?
Old Aug 16, 2011 | 07:38 PM
turbostang7's Avatar
yep you can put it on, probably wouldn't notice much though untill you get a tuner.
Old Aug 16, 2011 | 07:52 PM
dreese's Avatar
Ok thanks.What would make the turbo louder without buying another turbo?
Old Aug 16, 2011 | 08:11 PM
kdafire's Avatar
I put a boost valve on mine stock and could not really tell that much of a difference maybe 1-1.5 psi maybe not really enough to tell though
Old Aug 16, 2011 | 08:46 PM
ways of making your turbo louder are taking the resinator off of the intake, thats the thing on the top that says 6.6.
you can port the stock turbo horn to a bigger size that helped mine quite a bit.
straightpiping the exhaust helps some, but the biggest difference i did was got a metal intake from bills custom intakes, made the turbo sound like a jet .
Old Aug 16, 2011 | 11:39 PM
2500HeavyDuty's Avatar
yeah no problem puting it on stock
Old Aug 18, 2011 | 09:21 PM
dreese's Avatar
How much was the intake?
Old Aug 18, 2011 | 09:26 PM
it was around $200-$250 don't remember, look up bills custom intakes. he has some good prices and you can get a turbo horn to go with it and make it scream .
Old Aug 18, 2011 | 09:33 PM
dreese's Avatar
I checked the turbo horn. How does that install?
Old Aug 18, 2011 | 09:36 PM
not fun to be honest. i ported my stock one. they are a pain! if you get a 10mm gearwrench and a 1/4 inch 10mm wobley then it makes the job much easier. the bolt on the bottom is a pita!
i have heard that the new turbo horns he sells have a cutout for the bottom bolt so you can start it and then slide the horn over it. that would help a ton! i will be upgrading my stuff to one of his bigger intakes here someday with a turbo horn from him.
