chip????
Old Aug 15, 2011 | 08:03 PM
Bigred7.3's Avatar
Default chip????
how can you tell if a truck has been chiped or programed, i bought my truck used and everything is stock, but it smokes some wen you get on it, so it leads me to think it may have shom what of a chip, any way to kno for sure?
Old Aug 15, 2011 | 09:01 PM
ltr450's Avatar
these truck smoke when they are stock. my dads 06 smokes and it is stock.
Old Aug 16, 2011 | 10:22 PM
Bigred7.3's Avatar
ok cool thanks for the info, i just wanted to make sure,
Old Aug 29, 2011 | 12:06 AM
03ctd's Avatar
look under your hood for a chip...map sensor near your rail and injectors. if it has a chip youll see the extra conections and so forth.. or look near the steering wheel or by your knees...if you see a small hole with a switch they probably had one there at one point..the adjustable type. and as with tuner? get your ecm checked..not sure if there is any other way good luck
Old Aug 29, 2011 | 07:51 AM
cummins army's Avatar
look on the exhaust manifold if the is a plug in it then it more than likely had 1
Old Sep 15, 2011 | 08:12 AM
Bigred7.3's Avatar
I looked for every thing you guys said and found nothin so im gona go with its stock
cumminspwr11
Mar 27, 2015 11:40 PM
Dieselhead1052
Nov 26, 2014 05:43 PM
Dieselhead1052
Nov 26, 2014 05:42 PM
Paintrain64
Nov 25, 2014 06:29 PM
corey352
10
Nov 20, 2014 08:04 AM
