Classic cranks but doesn't start problem
Old Aug 11, 2011 | 01:29 PM
triumph_tech's Avatar
Default Classic cranks but doesn't start problem
My 96 psd won't start. Yesterday I left the shop to head home, the truck fired right up moved about 20 feet and shut off like I turned the key off. Now it cranks and cranks but won't fire. It isn't getting any fuel, no raw fuel smell or white smoke out the pipe. Put the scanner on it , no codes (p1111). Oil level in HPOP resevoir is OK. Changed the CMP but that didn't help. Read cranking RPM,VPWR,ICP,FUEL PW on the scanner. V PWR and RPM are within spec. ICP is only 165 psi and FUEL PW is .42 mS. Where do I go from here.....ICP sensor, IPR valve, HPOP? Truck has 140,000 miles. The shop manual says replace the IPR with a known good one first, OK for a dealer mechanic with a big parts room on hand, an expensive way to troubleshoot if you are paying the bill.
Old Aug 11, 2011 | 06:43 PM
fordornothing's Avatar
did you try the CPS? in alot of cases this is it.
Old Aug 11, 2011 | 06:55 PM
95powersmoker's Avatar
Did you try starting it without the ICP hooked up? ICP is low, I believe it needs somewhere near 500psi to start... Maybe need to clean the IPR... Here is a write up for that in case you need it.
File Type: pdf
Old Aug 11, 2011 | 07:18 PM
Did the CPS already, plus the RPM signal shows the sensor is ECM.
Yes I did try to disconnect the ICP, didn't start. With ICP disconnected, ECU showed 2400+ psi (max default pressure).
Last edited by triumph_tech; Aug 11, 2011 at 07:18 PM. Reason: Automerged Doublepost
Old Aug 11, 2011 | 08:55 PM
Dieselhead1052's Avatar
IPR valve??
Old Aug 12, 2011 | 08:28 AM
The IPR is the next stop on this trip. Is there any way I can tell if the ECM is sending the IPR the correct signal? I hate to disturb it for no reason.
Old Aug 17, 2011 | 01:02 PM
I changed the ICP sensor still didn't start so I changed the IPR and if fired up. The pressure at idle was 580 psi, a little on the low side and the idle is a little rougher than I remember. When I had the ICP out it looked like the rail wasn't totally full of oil. Will the air in the oil system work it's way out or is there a method to bleed the system?
Old Aug 17, 2011 | 04:26 PM
It will work its way out.
burndiesel
10
Feb 7, 2023 01:15 AM
Rusher48
Jul 2, 2020 08:39 AM
ish1521
Aug 26, 2015 08:42 PM
thurobred1320
May 5, 2015 09:26 PM
Tyler_302
Oct 22, 2014 07:08 PM
