Low fuel rail pressure codes
Old Aug 3, 2011 | 04:20 PM
Flswamprat's Avatar
Default Low fuel rail pressure codes
I just had my first CEL come on today with the Mini Max. Codes are P1011 no description and P087 low fuel rail pressure. 07,6.7 CTD. I would like to get some opinions as to the cause. I've been told weak rail plug,clogged fuel filter, or bad lift pump. More input would be great Thanks guys
Old Aug 3, 2011 | 06:03 PM
coors_man_2005's Avatar
thats where i would start is change fuel filter if dont help shim the rail releif valve or plug them two would be the cheapest easiest fix and check the psi on the lift pump make sure its not weak if so upgrade to a fass or airdog
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
vfizzano
17
Oct 9, 2014 02:26 PM
