pyro gauge install
Old Aug 2, 2011 | 07:53 PM
defarmer's Avatar
Default pyro gauge install
setting to installed a pyro gauge and was wandering the best location for install. also considering install a water injection system any input on them for the gallery. the truck is a 7.3 turbo idi. thanks
Old Aug 2, 2011 | 08:51 PM
DieselCrawler's Avatar
since you have a turbo, do all this with the motor running. install the probe in the driveside manifold inbetween the last 2 cyls. drill and tap it with the motor running. this will blow out the metal shavings instead of sending them threw the turbo. when you tap it, only go in 4 threads or so. pipe fittings are tapered, if you thread the tap all the way in, you will never get the fitting to seal. this locations can be done from under the hood
sorry pic is so big.
Old Aug 2, 2011 | 10:01 PM
defarmer's Avatar
awsome thanks never would have thought of doing it running to keep the shavings out
Old Nov 3, 2011 | 05:54 PM
ALWAYSREADYROB's Avatar
good tip
huntman7
Sep 4, 2015 04:49 AM
2gCummins
May 25, 2015 02:55 AM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
scottxmorris
Oct 8, 2014 02:14 PM
