finally got my parts truck... now what?
so i have my 96 f250. love it still but i wanted to convert the front end to solid front axle so i found a early 99 f350 which was also a 7.3. only thing its not coming with is the block. so with that said what can i use on my 96. i was hoping to use the intercooler, turbo, front and rear axles. so what can i and cant i use. possibly injectors.
The turbo is more or less an OBS turbo. The best thing for the injectors is to have them built into a set of hybrids. You can use the axles but it will take alot of work as you need to weld new hangers for the leaf springs. The intercooler you can use but the piping takes a little time to get it fabbed up right
Front Axle is a D50, again, not really worth the hassle to swap over.
If you do one, you need to do both or you will have to run SD wheels in the front and OBS in the back.
Not to mention your going to the dumbest design in the world, Unit bearings.
Keep your eye out for a D-60 out of a OBS F-350.
If it is truely a E99 it will have AB injectors which are 120cc, a pretty good jump from your 90CC AA's. I would grab the injectors, the IDM Intercooler and Y pipe.
The turbo is not really an upgrade, its a .84 wastegated housing, a bastard mounting system that was only used for that year and will gain you nothing.
The injectors are NOT pointless...
OBS- tuned on stock injectors- 260hp...
E-99- tuned on stock injectors- 290hp...
If you swap axles you will need new spring perches, new shocks, new brake lines, new drive lines and new wheels... for what? You gained a D-50 front end with Unit bearings.
When I dynoed mine it was 215/339 and 219/396
IIRC all you had on at that time was an EDGE ICP unit?
That was MANY years ago, and I am old so I could be wrong...LOL
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
