Oil pump
It's just a well-known fact I picked up while owning a superduty. If you can see a performance increase by getting a modded hpop and stock everything, then clearly the stock unit isn't up to par. And I haven't heard of one person installing a hopped up hpop and not report in positive results. Just saying
EDIT: In fact, I've heard of people doing some work to their trucks, such as tuner and supporting mods, and a CEL after a WOT run because the hpop cant keep up.
Well maybe i will run them with the stock pump and then i may get the hpop and see what the difference is. I only got 140k on my truck so i dont think the pump is wore out yet.
Thats not the point.. the point is these pumps dont come adequate enough for STOCK use, let alone high performance use. I mean, you can run the stock hpop... but you will NOT be getting the most out of your truck by any means.
Remember, an hpop and stage 1 sticks are both tunable upgrades. Both of those upgrades will take a retune to perform at their peak.
So making 500 on a stock oil pump isn't enough? The super duty runs AB and AD injectors the AD is a very oil hungry and the oil pump was not designed for performance use. Had they put something like an AC injector in the SD you would not have this problem.
To the OP you do not need to upgrade the oil pump you will run just fine. Will you benefit from one? Absolutely but it is not needed.
