Rosewood stage 2s
Im sure you'll enjoy them jim is easy to work with and had my injectors done in no time. Just make sure you are there when they are delivered fed ex requires signature I had to pick them up from the fed ex store.
If I were you I would not mess with stage 1's... Just go to the stage 2's.... a set of 180/100 will play fine with the stock turbo.
Hell I ran 238/100's for a while on the stockish SD turbo (1.00 exhaust housing) and other then WOT it was fine, even fun.
Yup stock turbo, power wise?......... Feels like a completly different truck. I went from maxing at 19lbs to 29lbs now and spools up there quick. Deffinately agree with CSIPSD go with the stage 2's.
Remember your stock turbo has a 1.15 exhaust housing, mine had a 1.00 or .84, I cant remember now.
Lower drive pressures with the 1.15, means a happier turbo.
