mods but no power 96 psd
I am brand new to anything diesel outside of a tractor. but I gutted my cat welded a pipe in place of my muffler, put k and n air filter, ts 6 pos chip. stretched the spring in my return valve(90 psi ) fuel. but no huge power gains. also when I had the cat off I cranked it to hear it and was supprised how quite it was. My f25o weighs out about 10,000 lbs with welding machine and service boxes full of crap. Help man
K&N's flow fine they just don't filter enough. So I would take that off and do a DIY intake. Im no expert but 90psi is a little much I have 65 going to mine now. You can all ways do a set of stage 1s that would help alot with power
If you are running 90psi on your fuel pump, you are taxing it way too much... Get it down to about 65-70psi...
Thats true if the ebpv is stuck the truck will be gutless. Put your hand in front of the exhaust pipe; if the exhaust is barely trickling out and not completely blasting your, the ebpv might be stuck
1ATony
1A Auto Parts
Jan 5, 2016 12:03 PM
1ATony
1A Auto Parts
Dec 7, 2015 01:09 PM
1ATony
1A Auto Parts
Oct 29, 2015 02:11 PM
May 10, 2015 10:57 PM
