Calling all Cummins leveled with 35's
Old Jul 20, 2011 | 07:18 PM
thehummincummins's Avatar
Default Calling all Cummins leveled with 35's
Hey guys I really need a couple questions answered here...
Can I run a 12.5 wide tire on an 8inch wide rim without any troubles?
The bolt pattern on my 2005 2500 cummins would be 8x6.5 correct ?
Do you guys think that a 17x8'' wheel, Backspacing 4.5 Offset 0.00 Would rub with 35x12.5 bfg MT's?
And will this wheel give me a wide stance with the 4.5 backspacing ?
Thanks alot need answer quick i have a chance to buy a set of wheels at a very good price!!
Old Jul 20, 2011 | 07:39 PM
cummins95's Avatar
i've got 35x12.50's on my truck right now with just a leveling kit. theyre on eagle alloy 17x9's with 4.5" of backspacing and -11 mm offset. they come extremely close to rubbing but i clear them. 8" wide rims might be a little skinny for the 12.50's. i really like the stance, i dont really care for the stuffed look for the wheel wells, thats why i picked up my 4.5" lift today. but to each his own
Old Jul 20, 2011 | 08:26 PM
Red_Rattler's Avatar
High Tech Redneck
my truck has kore "leveling" kit and I run stock rims with bfg mt 35x12.5x17 with zero issues.
Old Jul 20, 2011 | 08:54 PM
Nutty Jeeps's Avatar
cummins 95 what lift kit did you get? I'm looking to get one for my truck soon. If you have a link can you either throw it in here or pm me? Thanks bud
Old Jul 20, 2011 | 09:19 PM
Smoke 'em's Avatar
x2 on the lift link
Old Jul 20, 2011 | 09:49 PM
Youngblood's Avatar
No, you need a negative offset in order for the wheels to stick out giving you the wide look. Mine are -12mm offset and 5" backspace and only stick out 2", backspacing doesn't affect the way wheels stick out at all.
My Wheel and tire specs are: Tires 275/60/R20, Wheels 20x10 5" Backspacing, -12mm offset.
Also running a tough country 2" leveling kit.
Old Jul 20, 2011 | 09:52 PM
yeah ok thanks man I just did a bunch of reading and am kinda starting to get a handle on it.
Pro Comp Wheels 99-7981 - Pro Comp Xtreme Rock Crawler Series 99 Chrome Wheels - Overview - SummitRacing.com
Think im going to buy these they will be futher out from the control arms with the 4.25 backspace and -19mm offset (17x9'') wheel
does anybody see any issues with this on a leveled 2500 with 35''x12.5 bfg mt ??
*just in a rush because i need to order these asap thanks alot guys !
Old Jul 21, 2011 | 01:04 PM
1AMatt's Avatar
Site Sponsor - 1aauto
On a friends 03 3500 he had 315/70s on stock wheels with no lift for a while. They barely rubbed on the lower control arms. You should be perfectly fine
Old Jul 21, 2011 | 06:27 PM
cummins95's Avatar
here's the link to the lift i got. 1994-1999 Dodge Ram 3/4 & 1 Ton Pickup 3/4 Ton4.5" Long Arm" lift kit 213H | BDS Suspension
Old Jul 21, 2011 | 09:46 PM
does anybody see any issues with this on a leveled 2500 with 35''x12.5 bfg mt ?? or think they will rub the fender hard ?
