smoke!!!
Old Jul 13, 2011 | 10:40 PM
shorty2tall's Avatar
Default smoke!!!
ok so got the up pipes on and took it for a drive and well now its smoking i also did the ccv mod. it was kinda pinched then moved hope it'd help with smoke. it didnt.
i smelt it it burns the back of ur throat it seems. is that injectors?
also when drive at same speed/rpm it stops and starts.
need help!!!
Old Jul 14, 2011 | 11:14 AM
Default smoke!!!
What could've happen to make it smoke all of a sudden? All I did was my up pipes.
It's coming out the tail pipe btw.
Patrick
Old Jul 14, 2011 | 12:23 PM
prison's Avatar
Is it colored?
Old Jul 14, 2011 | 12:24 PM
Default smoke!!!
Ya blue and it seems I have more blow by now. If the ccv tube got pinched enough could my rings have gone bye bye?
also it doesn't start to smoke till the engine gets to operating temperature. looks like the back bolt on the turbo might have some oil on it so im going to check that on monday. or over the weekend if i have time.
Patrick
Old Jul 14, 2011 | 06:02 PM
95powersmoker's Avatar
What did you do with your uppipes? Did you remove the turbo?
Old Jul 14, 2011 | 07:14 PM
pulled the old pipes off put the new pipes on and yes the turbo came off. it also looks like there might be a little oil around the back bolt that holds down the turbo but not alot at all.....
so what do u guys think the ccv tube got pinched idk how well do u think it could've killed the rings on the pistons? or some o-rings somewhere or would it had to have been a really good pinch?
Old Jul 15, 2011 | 01:07 PM
Bad93Cummins's Avatar
What does blue smoke idicate at first start, slight haze but goes away?
Old Jul 15, 2011 | 05:35 PM
How did the Turbo orings look? Did you make sure they didn't shift at all when you reinstalled the turbo?
You're burning oil... If it goes away fairly quickly, I wouldn't worry...
Old Jul 15, 2011 | 05:58 PM
So rings are bad/worn? Is white smoke what idicates turbo need rebuilt?
Old Jul 15, 2011 | 06:09 PM
No not necessarily, it could be bad Injector orings, could be turbo orings...
White smoke can mean a couple of things, bad injectors, coolant...
