VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
Need Help
Old Jul 12, 2011 | 09:35 PM
DanLowe's Avatar
Default Need Help
2006 VW Jetta TDI. I changed my air filter the other day and found what appeared to be engine oil in the air filter. Also, when the throttle is pressed and let off, a strange sound like a vaccum leak makes itself known. Any thoughts on this???
Old Jul 19, 2011 | 02:13 AM
Deezel Stink3r's Avatar
Neglect the oil -this appears to be normal as long you don't have a puddle of oil inside the air box.This would indicate something going wrong like a blocked turbo oil drain pipe.
All VW's I had have this oil coming from the PCV return pipe. It is absolute normal.
The other thing sounds like a boost pipe leak to me. Check the hoses and the clamps. check also lose connectors like vaccum hoses.Sometimes you popp them off while maintenance.
I hope this helps.
Old Jul 19, 2011 | 09:53 PM
DanLowe's Avatar
It may, all of the forums I have checked all said the same thing. EGR system malfunction. I'm going to check into that.
Old Jul 20, 2011 | 12:40 AM
You mean the strange sound?
Old Jul 20, 2011 | 11:35 PM
DanLowe's Avatar
Yeah, mainly the sound.
Old Oct 1, 2011 | 03:15 PM
85_305's Avatar
Being Evaluated
that 'strange sound' might just be the vnt blowing off. do you have an exhaust or intake on the car?
