leaking oil
Old Jun 30, 2011 | 11:30 PM
smokenrubber's Avatar
Default leaking oil
Have a 05 dodge that is leaking oil from the back of the motor. does not seem to be leaking from the oil cooler or from the valve cover. Is there any other place that it could possibley leak from back there
Old Jul 1, 2011 | 12:42 AM
rednekroper05's Avatar
Default leaking oil
It's up high on the block or lower on the passenger side towards the back
Old Jul 1, 2011 | 10:32 AM
It seems to be high on the drivers side, but there is so much oil under there it so hard to tell, i was 3 hrs from home when i spotted the oil leaking on the ground.I kept adding oil to get it home and used 2 gal by the time i got home, so it a good size leak. That morning when i started it up it was idling ruff and blue smoke was coming out of the tail pipe, but it cleared up after a bit, never had that happen before.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
