fuel problems?
Old Jun 26, 2011 | 02:44 AM
black_smoke24v's Avatar
Default fuel problems?
i have a 04 dodge ram 3500 drw 5.9 24v ho, just put a new motor i believe it is a fuel problem. it starts and runs for about 15 - 20 min and starts blowing white smoke and eventually dies. put diagnostics on truck and is not putting out any codes. ideas at all?
Old Jun 26, 2011 | 08:14 AM
zeismaster's Avatar
I'm not 100% sure but white smoke sometimes means injectors. I have seen trucks with big injectors blow white smoke but they are not stalling but I have also seen trucks with bad injectors blow white smoke but just run extremely bad but not die.
Old Jun 26, 2011 | 08:34 AM
silverbullet1's Avatar
with a new motor im assuming it has new injectors also? if so from what ive seen on new/rebuilt injectors they white smoke for the first 100-200 miles then clear up, but if its persistant i would say possibly a sticky injector.
Old Jun 26, 2011 | 12:59 PM
it isn't a brand new engine but new to me it has less than 90000 miles on it but my truck sat for almost six months before i got the engine i thought maybe the pump in the fuel tank went bad maybe. did not want to spend $250 on a new pump without getting a better idea on what maybe the problem
Old Jun 26, 2011 | 01:25 PM
zeismaster's Avatar
I'd personally say since everything is not new that I would at least have the injectors tested. To me sounds to be some sort of injector problem
Old Jun 27, 2011 | 01:51 AM
I would say injector sticking or something along those linesor possibly bad/old fuel. From what I've seen when the lift pump starts to go it either fails completely or causes the truck to surge and die. It would be a good investment to change the pump regardless so u won't have to worry about it.
gillespie3033
Chevy/GMC Duramax 01-04 LB7
29
Jun 25, 2015 03:51 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 24, 2015 01:13 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
