Passenger Vehicles General Discussion General Diesel Discussion of all Passenger Vehicles with Diesel Engines
Mercury Meta One Concept
Old Dec 25, 2007 | 12:32 AM
Diesel Bombers's Avatar
Staff Reporter
Information Mercury Meta One Concept
Mercury Meta One Concept - The Mercury Meta One
So you want an efficient hybrid vehicle but can't imagine yourself driving a dorky, gas-powered Jetsons bubblemobile like the Toyota Prius that makes only 133 hp (after the electric motor kicks in). Well, the engineers at Mercury obviously felt the same way and designed the Meta One concept SUV--a vehicle with a diesel/electric hybrid powertrain that's based on a tweaked Lion 2.7L, twin-turbo V-6 that creates a massive 431 lb-ft of torque (without electric assistance). A 35kw (47hp) electric motor replaces the flywheel, starter, and alternator and enables the engine to freewheel when electric power isn't needed to reduce soot-causing engine loads. To meet California's superstrict AT-PZEV emissions rules, the system uses dual catalysts in the exhaust manifolds before the turbos, a gigantic oxidation catalyst/ diesel particulate filter that stretches over much of the wheelbase, dual-walled exhaust pipes, and a urea-spraying system to reduce NOx.
Even with all those extra parts, the batteries, and the electric motor, the Meta One weighs just 4,250 pounds, which is 500 pounds less than the Jeep Grand Cherokee diesel we tested ("First Drive," Nov. '07), so getting more than 30 mpg should be no problem.
Engine: 2.7L Lion V-6Displacement: 2.7L (166 ci)Configuration: 60-degree V-6Horsepower (diesel only): 248 at 4,000 rpmHorsepower (diesel/electric): 295hp Torque: 431 lb-ft at 1,900 rpm
Head material: Cast aluminumBlock material: Compacted graphite iron (CGI)Bore and stroke (IN.): 3.19 x 3.47Valvetrain: DOHC, 24-valvesFuel injection: High-pressure common-rail with piezo injectors
Turbos: Two variable-geometry turbosmissions control: Preturbo oxidation catalysts, post-turbo oxidationcatalysts, cooled EGR, diesel particulate filter, and urea selectivecatalytic reduction
Emissions category: Advanced Technology Partial Zero-Emissions Vehicle (AT-PZEV)
Transmission: Six-speed modular hybridElectric motor: 35 kw (47 hp)Traction battery: 325-volt, 6-Ah air-cooled NiMH
Photo Gallery: Mercury Meta One Concept - Hybrid Diesel Engine - Diesel Power Magazine
Read More | Digg It | Add to del.icio.us
More...
Old Jan 4, 2008 | 09:07 AM
Blue01F250's Avatar
Duramax Virgin
now that will be cool -- a diesel/electric hybrid... can't wait to see it actually on the road...
Nov 20, 2014 06:20 PM
Nov 20, 2014 03:30 PM
Nov 19, 2014 06:00 PM
Nov 3, 2014 01:40 PM
Sep 27, 2014 12:10 PM
