CP3 failure?
Old Jun 18, 2011 | 10:54 PM
The Don's Avatar
Default CP3 failure?
My beast is now giving me a lope when I come to a stop. The light gray smoke at the lights after a 50 mile drive and requires a hard acceleration to clear. Still showing no codes. The dealer double cheked the balance rates again, and fuel pressure fluctuates between 21K and 23K PSI. Dealer said pressure is in the normal opperating range. Hmmmm?? Any thoughts?
Ok over 30 people have read the post and nobody had any thoughts. This site doesn't appear to be as helpful as was suggested to me.
Old Jun 19, 2011 | 07:41 AM
BriteWhiteRam's Avatar
still sounds like bad injectors to me
Find another dealer, injectors max tolerance is +/-4 in park and +/-6 in gear, if they are out of that spec then they are damaged, on my LBZ they rarely ever go more than +/-2 in park
Old Jun 20, 2011 | 04:32 AM
2500HeavyDuty's Avatar
I have some tech articles that describe and help diagnose a bad cp3 posted up somewhere on this site, it has been moved fro, its original so you will have to search through the multiple threads I have made.
Basically if there is a flucuation that's real bad it could be theredulator on the back of the cp3. But that's not said in stone. If i had a working computer I would be more able to help you out and direct you to the correct tech post.
Old Jun 20, 2011 | 04:34 AM
You can click on the link here and it will show you all my threads, the majority are tech.
https://www.dieselbombers.com/search...&starteronly=1
Old Jun 21, 2011 | 11:48 PM
The Don's Avatar
I do appreciate the link some of your posts I wasn't able to find without it.
Jun 26, 2015 10:30 AM
childs25
May 10, 2015 01:50 PM
crusty
5.9L CR Performance
Apr 26, 2015 03:31 PM
schwier94
17
Apr 7, 2015 03:16 PM
schwier94
Mar 24, 2015 12:18 PM
