Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
12V and 24V Cummins Tool Kit
Old Mar 28, 2007 | 10:34 PM
Default 12V and 24V Cummins Tool Kit
Thought you guys might be interested....I picked up a tool kit from Cummins...it includes everything needed to do an oil change and valve lash adjustment (including the barring tool) - this is a cheap way to buy the barring tool. Price was $85 minus 10% (Canadian dollars - probably about half that for you guys with real money).
Cummins p/n: 3399869 - BTW, all the tools are made in the U.S. (KD Tools)
Old Mar 28, 2007 | 10:35 PM
CTD610's Avatar
Originally Posted by Dr. Evil
Thought you guys might be interested....I picked up a tool kit from Cummins...it includes everything needed to do an oil change and valve lash adjustment (included the barring tool). Price was $85 minus 10%.
[IMG]http://i14.photobucket.com/albums/a329/DrEvilx/100_1274.jpg[/IMG
Nice. Where did you get it?? Cummins dealer???
Old Mar 28, 2007 | 10:41 PM
yup...right at a Cummins Service Center....
Old Mar 28, 2007 | 10:49 PM
CTD610's Avatar
Thanks for the quick reply.....
Just one question, Can you tell us everything (socket sizes and such) that are included in the kit or provide us with a link that will tell us??
Again, thanks Dr. Evil..........
Old Mar 28, 2007 | 10:57 PM
No Problem...
- a proper oil filter wrench
- 3/8" x 6" extension
- stubby flatblade screwdriver
- barring tool
- metric feeler guage
- 2 wrenches (14 mm, 15 mm)
- 3/8" flexhead ratchet
- 10, 12, 13, 14, 15, 17, 19 mm
- 3/8" x 1/2" adapter
- all in a good case.
Old Mar 29, 2007 | 01:22 AM
Maj Easy's Avatar
B Series Valve Clearance Adjustment (2nd gen guys)
http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
4. Insert the barring tool into the bellhousing hole. Insert a 1/2 drive wrench into the barring tool, and turn the crankshaft slowly, while watching the valve train. Press the timing pin to locate Top Dead Center (TDC) for cylinder No.1.
If no barring tool is available, the crankshaft may be turned with a 22 mm socket on the alternator pulley bolt. Rotate the engine clockwise when viewing from the front of the truck. This method turns the engine backwards, so make sure you are adjusting the correct valves.
You can also turn the engine with a 15mm socket on one of the harmonic balancer pulley bolts.
Old Mar 29, 2007 | 01:31 AM
Yup that will work...but sometimes its just nice to have the right tool for the job....
Old Mar 29, 2007 | 12:30 PM
Plhorseman's Avatar
Is the rubber plug on the bell housing easy to see/find? I read that it is on the passenger's side, I'm just not sure I've actually seen it.
Old Mar 29, 2007 | 01:11 PM
It is on the passenger side...
Old Mar 29, 2007 | 02:00 PM
ndurbin's Avatar
Those barring tools are handy as hell to have, beats using the altenator any day.
I have acouple of long extensions (ends up being like 3-4' total when their put together) and a swivel deal I stick into the barring tool. The swivel allows me to angle the extensions up to come out by the alt. and I can turn it fromt he front of the truck. No running back and forth underneath the truck.
