New tire ?
Old Jun 9, 2011 | 04:23 PM
jimbow's Avatar
Default New tire ?
Just picked up some Nitto Terra Grappler in 285-75-17E,any input as far as tire pressure front to rear and loaded vs.unloaded? Thanks
Old Jun 9, 2011 | 05:10 PM
redneckpipeliner's Avatar
For maximum life and mpg, use the number on the side of the tire when loaded, when unloaded for a softer ride, 10% less. I run 70lbs in the back and 75lbs in the front on my F350 with tires rated to 80lbs. If I load it I will have 80 all the way around. I wouldnt go below 65lbs on an 80lb tire.
Old Jun 10, 2011 | 05:15 PM
jimbow's Avatar
Thanks
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
Supremedragonx
Mar 1, 2015 01:50 PM
veggyoilkid
Nov 5, 2014 01:34 PM
