ring and pinion toast help id my axle
Old Jun 8, 2011 | 07:17 PM
luke46's Avatar
Default ring and pinion toast help id my axle
Got a 99 f250 6 speed four wheel drive extended cab I broke the pinion it took out the reluctor ring and ring gear too not sure exactly what axle I have its 373 ratio so what can replace it where is a good place to get the parts I can do gears but if I can get a full axle for cheap ill do that just need to know what will swap thanks im not good with ford axles yet
Old Jun 8, 2011 | 08:59 PM
95powersmoker's Avatar
You have a 10.5" sterling... Same on all 99-03 trucks...
Old Jun 8, 2011 | 10:10 PM
CSIPSD's Avatar
Yup
Old Jun 8, 2011 | 10:42 PM
Originally Posted by CSIPSD
Yup
Talk about a....
LOL... I know what you're gonna say... Damn kids...
Old Jun 8, 2011 | 10:48 PM
CSIPSD's Avatar
not sure what your talking about...
Old Jun 9, 2011 | 12:17 AM
Riffraff Performance's Avatar
FormerVendor
I have a spare set if you need them....
Old Jun 9, 2011 | 05:49 PM
luke46's Avatar
Looks like I need pinion ring gear and probably the carrier since it took out the reluctor ring my speedo wont work without it. thanks folks I was just wondering because on the ring gear it saysF1025-373 figured it might be the 10.25 and i made sure its 3.73s 41 teeth by 11 teeth. But I will start looking around. thanks again.
Old Jun 9, 2011 | 06:00 PM
CSIPSD's Avatar
Same gear goes in the 10.5 and the 10.25... but anything superduty is a 10.5
Old Jun 9, 2011 | 10:34 PM
luke46's Avatar
CCool thanks
Old Jun 11, 2011 | 08:04 AM
luke46's Avatar
Since I ended up breaking a bunch of stuff I was looking at just swapping in a used axle but everyone will only sell an exact match mine is a 409c tag but can I just stick any 3.73 axle in from 99 to to 03
