Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
help please
Old Jun 8, 2011 | 05:20 PM
roycer's Avatar
Default help please
I believe my blower control module is gone, fan wont stop running..
I know what i need but im having a hard time removing black plastic under passenger side dash. I 7mm bolt came out, 2nd wont compltely let go, 3rd is by hump and almost impossible to get at..
thanks for your time, Royce R
Old Jun 8, 2011 | 10:16 PM
biged681985's Avatar
sometimes u just gotta fight em. have u tried a 1/4 swivel on it?
Old Jun 9, 2011 | 07:54 AM
Rttoys's Avatar
Don't worry about the one on the hump. Just remove the 2 you can get to and just push the cover down. There is enough room to work with it still attached by the 3rd screw.
You'll probably need the module and a new connector. The pos usually burns and both need to be replaced.
Old Jun 9, 2011 | 01:23 PM
roycer's Avatar
Default the second screw is backed all the way out but??
It doesnt seem to wanna come out even put pliers on it wiggle and pull at same time, is it suppose to come out?? Ill leave 3 rd screw in..
stupid question... I was going to order blower control module it comes with the black and purple wires and plug that plug into blower,, but what is the connector that you mentioned?? thanks again Royce
Old Jun 9, 2011 | 02:44 PM
Rttoys's Avatar
The blower module connector- AC Delco # PT2195 or GM# 15862656
It's the connection from the control head to module. Once you wiggle the case cover out of your way, pull the 7-way connectior from the module and look at it. If it's burned, you'll see a dark burn on the red wire, black wire, or both. Since yours is constantly running, it my not be burned. Just something to look for while you are there.
Sure those are 7mm screws? They might be 5.5mm Don't remember at the moment. Get the 2 out and it should drop the plastic down.
