mt45 5.9 cummins engin check codes
Old Jun 7, 2011 | 11:04 AM
jimjames's Avatar
Default mt45 5.9 cummins engin check codes
Dear Bombers,
I've recently bought an MT45 (X-FedEx) truck. I am losing power at top speed, then I need to down shift and build up RPMs and it runs fine for a while. Well it has a check engine button that gives flashing light codes (two number codes). Please does anybody have a list of these codes.
Thanks Jimmy
Old Jun 7, 2011 | 11:12 AM
Farmboy 2.0's Avatar
The retrieval of codes does not constitute an engine diagnosis. However, there are some codes that usually indicate a defective injection pump. A current P1688 always means that the pump is bad, there is no further diagnosis required. Code P0216 is probably the most common code for VP-44 Pumps. If transfer pump pressure has been checked and is O.K., the injection pump is defective. Other codes that are less common are P0180, P0181, P0215, P0251, P0252, P0253, P0254, P0370, P1287, P1689 and P1690. These codes USUALLY, but not always indicate a defective pump. There are wiring and power checks to be performed if these codes are present. These codes relate to Dodge pickups only, and are not for any other ISB application.
Old Jun 7, 2011 | 11:20 AM
jimjames's Avatar
Thanks Scott,
I'd like to find out what the 2 number codes on my dash check engine system mean. Please let me know if hear anything.
Thanks
Old Jun 7, 2011 | 11:28 AM
What are the codes? Have you got them read?
Old Jun 7, 2011 | 12:17 PM
jimjames's Avatar
Dear Scott,
The codes are: 43 44 34 27 82 78 43. I may have mis-interperated the pauses in the blinking lights and maybe it's 342 & 782.
Thank you.
Old Jun 7, 2011 | 12:22 PM
I have never seen codes like that before
Old Jun 7, 2011 | 12:54 PM
jimjames's Avatar
I know. I seen the others but not these.
Old Jun 9, 2011 | 05:12 PM
keithduke01's Avatar
get me the engine serial number and i will see if cummins quickserve has anything online about it.
Old Jun 13, 2011 | 12:35 PM
jimjames's Avatar
Default Thanks Ace!
Dear Keith,
It's a 5.9 ISB, No. 45653548.
Jim
Old Jun 13, 2011 | 09:25 PM
thanks ill see what i can come up with on the two digit codes or diagnostic tree for your symptoms tomorrow and let you know what i can find.
